6/15/2017 1:20pm
So basically I have 2 CR125s. I bought a 2002 CR125 for $1000 (pretty good deal in Australia) and it works 100%. Just really dirty and needed a suspension overhaul. But it worked and was 100% complete. Then I have my 1998 CR125 which was my first big bike after I stopped riding in my teens and it's a good bike, just stiff and looks dated, but the engine is pretty damn nice (I fully rebuilt it 10 hours ago, runs like a dream).
I know it was mostly the cylinder that changed over the years but I was wondering if it would be worth my while swapping the engines over? Is it a clean swap, or am I looking at just the cylinders (and I think the power valve rod thing)? I keep reading that the latter model CRs, specially the 125s were slow as balls.
Good idea to swap the '98 carb over as well?
I started with a blown up 2002 and purchased a complete '92 top end. After doing a bottom end rebuild with the '92 powervalve actuator in place of my '02 it booted right up. I'm having issues now with exhaust fitment, mainly because I have an 05-07 pipe, and the old style cylinders hit the pipe.... but a ball peen hammer and a set of torches work wonders.
As for the carb.... If yours has the Mikuni throw it in the garbage. Get yourself a 38mm Keihin PWK Airstriker from JD Jetting.
sliced pipe
welded pipe
power valve covers
Well I have a spare '98 cylinder so I might just wait til the '03 engine is about to blow and then rebuild it. I'm guessing I'll need pistons and rings to suit that cylinder too.
And that carb is an awesome deal from JD Jetting. I think the jetting kit alone is near on $80. I've read the '07 air boot is also a good mod. My budget is roughly 2k, so this should all fall under.
theyre both slow
If it's just a matter of sizing for the engine swap I might make up some sleeves or whatever for the engine bolts then (I have to do a similar thing for my NSR250 MC21/28 project).
Get an 05-07 air boot, the airstriker carb, and Vforce 3/rad valve. That'll wake her up
TB901, Cases from 92-97 should be same. Not 100% sure after that I know my '02 bottom end case had a few different things than my 95 era ones do but haven't tried to see if they matched. Anything up to '02 should work if you buy both bottom center cases though...........
Post a reply to: 2003 CR125 + 1998 CR125 engine?
