CR250 front fender conversion
JB 19
Marion, OH US
Edited Date/Time 9/7/2015 10:28am
Last week I bought an 03 CR250 and it needs new plastic. I was going to put the 04+ plate and front fender on, but have saw a few with 09 and up 450 front fenders. I can't seem to track down any pics of this setup. Can someone post a few if they have any?
Two years ago I had an 05 that I wished I hadn't sold so this is my new 2stroke fix.
JB 19
Marion, OH US
2/11/2013 5:10pm
I went ahead and pulled my 450 fender and plate off and spotted and drilled some holes.
This bike has a long way to go cosmetically. Motor sounds and feels new, but I think it was mostly trail rode and left dirty after every ride. Going to order new plastic and and then mostly for safety purposes go over the whole bike.
Before:
After:
JW381
Harrisburg, OR US
2/11/2013 7:13pm
Wow, looks so much more up to date. I have the newer CR plastic, but I'm pretty sure I'm gonna do this too.
Barnett117
Aledo, IL US
1562nd
2/11/2013 10:37pm
JB 19 wrote:
Last week I bought an 03 CR250 and it needs new plastic. I was going to put the 04+ plate and front fender on, but have...
Built this myself. 2001 CR125 with 2012 CRF250R plastics, If you want any help let me know and I would be happy to!
JB 19
Marion, OH US
2/12/2013 2:58am
Yeah, it does seem to freshen up the look.
Barnett > Looks good. I bet that was a lot .of work. I'll probably stay with stock with everything else except a white rear fender. I'll let you know if I decide to jump in the deep end.
JW381
Harrisburg, OR US
2/12/2013 2:29pm
JB 19 wrote:
Yeah, it does seem to freshen up the look. Barnett > Looks good. I bet that was a lot .of work. I'll probably stay with stock...
How hard was it to fit the 09+ stuff on there?
JB 19
Marion, OH US
2/12/2013 6:09pm
It was easy for the fender. I have only drilled the front two holes so far because I just wanted to see how it looks.
- I used the same bolt spread width as the CR fender which is also the same as the 450.
- Center drilled a small hole and then drilled a 23/64 hole. This is a good size for the stock fender washers to fit into.
- If I remember right I drilled the holes 9/16 of an inch on center from the step in the 450 fender and in line with the holes that are already there..
Real simple.
When I get some time in the next few days at work I'll make a bracket for the number plate to bolt on using the stock CR mount. At this point it is just sitting where it would go.
Anyone recommend a company for after market plastic? I would like to support Cycra since they are in Ohio. Polisport has cheap stuff, but not sure how durable it is...also Acerbis and UFO? I should just get Cycra. OEM Honda is out of the question because of price.
JB 19
Marion, OH US
2/24/2013 5:37pm
A small update.
G Force
Winnipeg CA
3/9/2013 3:09pm
Looks great!
What year front fender and plate?
3/10/2013 4:36pm
JB 19 wrote:
A small update. [img]https://sphotos-b.xx.fbcdn.net/hphotos-ash3/11510_4559196305159_1637304690_n.jpg[/img]
A small update.
looks so much better with new 450/250 fender and plastics. i like how you put the white rear fender on modernized the bike thumbs up!!
3/12/2013 10:38am
We use a fender from a 2009-2012 crf450r or 2010-2013 crf250r and a cycra stadium plate for those same models.
3/12/2013 10:39am
Next time we will make a bracket to use the stock front # plate mounting tabs
JB 19
Marion, OH US
3/12/2013 10:09pm
RACESTHILAIRE > Its amazing how much fresh it makes the look of the older bikes. Even your 2000-2001 model there looks great.
3/13/2013 7:19am
It definitely does freshen up the look. That bike was a complete basket case build we did that came in with the handlebars snapped off, no rear fender, mud stained, etc. I think it turned out okay!
3/13/2013 7:28am
Mine. When you use a CRF upper clamp and a Cycra plate, you just put a hole for one 8mm bolt through the top center and all your number plate woes are solved.
G Force
Winnipeg CA
3/14/2013 7:23am
Anyone seen this done with a KX250?
3/14/2013 11:00am
A front fender is just 4 bolt holes and a bottom triple clamp. As long as you have the accompanying front plate, you can put whatever you want, on any bike you want. Having a Cycra plate makes it that much easier because they mount with 3 zip ties.
Top End
NOR-CAL, CA US
3/15/2013 11:59pm
Looks good, are the fork guards still the same from 2002CR's to 2013 CRF's?
3/16/2013 3:09pm
usualy the fork guards are speciic to the fork itself because of the lug. and the 09-12 have KYBs. the likelihood of the KYB and the Showa lug being identical, is pretty low.
Shauns867
Salt Lake City, UT US
12/14/2013 3:30pm
[img]https://p.vitalmx.com/photos/forums/2013/03/12/016_878300.JPG[/img] We use a fender from a 2009-2012 crf450r or 2010-2013 crf250r and a cycra stadium plate for those same models.
can you put a picture up of the top mounting point?
4/25/2014 12:55pm
I have an 07 CRF 450. Do you guys know if they make triple clamps that would allow the newer from number plate and fender to just bolt up??
JB 19
Marion, OH US
4/25/2014 3:10pm Edited Date/Time 4/25/2014 3:11pm
I have an 07 CRF 450. Do you guys know if they make triple clamps that would allow the newer from number plate and fender to...
You should be able to use the newer fender/plate with your 07 without changing the clamps. It's mostly a matter of lining up the fender and drilling new holes. You have be a little creative with mounting the number plate. Some make a bracket or use zip ties.
4/26/2014 10:40am Edited Date/Time 4/26/2014 10:46am
JB 19 wrote:
You should be able to use the newer fender/plate with your 07 without changing the clamps. It's mostly a matter of lining up the fender and...
Yeah that is what I did already, the fender bolted up good just not real stoked on the number plate.
Looking at my buddies 05 CRF 450 with Ride Engineering triple clamp it looks like they have the tabs to mount the new plate, as well as the center hole mount.
Brad2502
Cameron, IL US
7/31/2014 10:43am
Just so I'm perfectly clear, for an '01 CR250, I can use EITHER an 09-12 crf450 OR an 10-13 crf250 cycra fender and cyra stadium plate? Is there any real difference between the two? What do you recommend as the better option? Also, any recommendations for side plates or rear fender? Trying to do an easy upgrade. Your '01 looks very clean. I love the style.
Mickolobe7
Chicago, IL US
8/1/2014 7:09pm
Barnett117 wrote:
[img]https://p.vitalmx.com/photos/forums/2013/02/11/honda117_2_616700.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2013/02/11/honda117_4_527979.jpg[/img] Built this myself. 2001 CR125 with 2012 CRF250R plastics, If you want any help let me know and I would be happy to!
What did you have to do to get the 13 plastics on? I have a 2008 CRF 450r and 13 front fender and plate but didn't try to do the shrouds and side plates and rear fender.
-eagle-
ZW
8/6/2014 12:26pm
Any word on UFO restyling any other two strokes besides the Yamaha?
Flip109
TX US
11/11/2014 4:46am Edited Date/Time 11/11/2014 4:54am
Just scored a fairly clean 2000 cr125. only thing shitty is the fenders and graphics are really faded. Gonna try and update the look. So far I'm gonna order:
10' CRF250 front fender
cycra stadium front number plate
white rear fender
graphics and seat cover
Any other suggestions?
Does anyone know if the side shrouds on a 04 cr125 will fit on the 2000?
Thanks for any help in advance!
Flip109
TX US
11/11/2014 4:47am
Mickolobe7 wrote:
What did you have to do to get the 13 plastics on? I have a 2008 CRF 450r and 13 front fender and plate but didn't...
Yea how did you get those rear number plates and fender to line up?? Could you post some close up pics of what you did??
whiplash250r
Battle Ground, WA US
5/17/2015 3:26pm
Just bought a 2000 250 yesterday. Very interested in what you've done,what tank,airbox,ect.
Jordanb23
Carson City, NV US
9/7/2015 10:28am
2001 cr250 with 2015 crf450 plate and Finder! Just had to redrill a little
xr200r
OR US
11/26/2016 9:31pm
Does anybody here know if a 2001 cr250 front fender will fit a 2001 xr200
Post a reply to: CR250 front fender conversion
