2004 Kx125 Rear Shock Swap
djp48
Ludington, MI US
Edited Date/Time 11/25/2021 12:22am
Going to be doing suspension overhaul and just exploring options.
Trying to find the best way to get high low speed adjustment.
Another member mentioned replacing the stock valve with one from Technical Touch which is a fine solution.
Do you all know if there is a shock with high low speed adjustment that is mostly a direct replacement.
How about 96-07 RM 125/ 250?
I see mentions of it, but haven't read anything for sure.
11/11/2021 6:27am
2000 kx 125/250 shock and you change the chape, it was on my 125 and 250 kx.
djp48
Ludington, MI US
11/11/2021 9:02am Edited Date/Time 11/11/2021 9:05am
2000 kx 125/250 shock and you change the chape, it was on my 125 and 250 kx.[img]https://p.vitalmx.com/photos/forums/2021/11/11/517921/s1200_received_478049886039902.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2021/11/11/517922/s1200_received_2034689789981324.jpg[/img]
Could you define chape?
What forks you running on your kx in the photos?
djp48
Ludington, MI US
11/13/2021 4:45pm Edited Date/Time 11/13/2021 4:46pm
jujusuzukirm
For shock you must change this parts and 99 or 2000 kx shock be used.
My fork is à 2011 kxf, clamps for 2011 kxf ( wheels and brake ans wheels kx 250 )
irm
djp48
Ludington, MI US
11/13/2021 5:09pm Edited Date/Time 11/13/2021 5:21pm
So I have 2019 kx 450 forks coming. I think I have the front end parts sorted out.
As far as the rear I have a few questions. Quite a few.
A-kit kx shock assembly- Possibility if I can find one at reasonable price.
A-kit kx body with oem kxf internals- Will the oem kxf internals transfer over to a kx a-kit body?
Stock body with kxf internal and aftermarket high low speed adjustment- is it possible to put the 18mm kxf internals in the stock body?
Rm shock assembly- i see this has been done but can't find what it entails. There is a showa version with an 18mm shaft and high low speed adjustment. 2005-2007 I believe. I like the idea of having a showa shock to go with the forks.
Any other suggestions?
djp48
Ludington, MI US
11/13/2021 5:25pm Edited Date/Time 11/14/2021 4:53am
Can anyone identify this shock for certain?
rm 125 shock
Late model rm?
djp48
Ludington, MI US
11/14/2021 4:49am Edited Date/Time 11/14/2021 4:58am
What years and is that for sure?
A lot of this is me assuming and putting together little bits and pieces together from unconfirmed sources.
I believe the first couple of years rmz shared the same shock as the last couple of years of the rm 05-07.
At some point kawasaki and suzuki joined forces and the kxf/rmz where pretty much the same bike.
Kxf shock body is to long changing overall shock length.
From mx techs fitment guide-
MXT National Shock for KX 125 (96-05), KX 250 (96-07), RM 125 (97-07), RM 250 (96-07)
What this tells me is there are some things in common here between years, makes and models. I'm not sure if there are other options after check out.
Also still curious about how all the kx and kxf bodies/internals/oem/ a-kit stuff all work together.
Are a-kit bodies i.d. for the dampener oversized from stock?
Lost my mind.
11/14/2021 9:00am
djp48 wrote:
What years and is that for sure? A lot of this is me assuming and putting together little bits and pieces together from unconfirmed sources. I...
Lost my mind.
I had used a 2010 ohlins rmz shock on my 2008 kx 125 and no modification to install
11/14/2021 9:05am
You can used kx 250 2006/2008, i had used on my fast house kx 125 2006
You have à lot of options
djp48
Ludington, MI US
11/14/2021 11:43am
I ordered an 05 rm125 rear shock. Looks the same as the rm shock used in a magazine build. Should have 18mm shaft and high low compression. Couldn't find any specs for the oal so we will see when I get it. Worse case scenario I'll resell it since there are only a couple options on ebay. Body is coated and is said to be in good shape. I'll post up when I know more about fitment.
Still open for suggestions.
DJV804
Albertville, MN US
11/14/2021 7:26pm
Your best bet is just getting an aftermarket adjuster and not messing with retrofitting something. However you seem to be set on going down this road that a ton of us have already tried to go down, so:
For the rmz shock, 04-06 can work, these were the years the kxf and rmz were a shared bike(only 04-05 on the kxf, rmz lasted 1 more year), anything kxf later can not. I tried going down the route with a newer rmz and kxf shock. The body is longer than the Kx and it bottoms too early. Can you do it? Yes. Does it work how it should and is it the right way? No.
I don’t know about RM shocks but I believe you’re going to have to swap the clevis at the very least, but I could be wrong. I never went that route because I found an a-kit shock.
Kxf never had 18mm shaft stock, even now on the 2021/22, and internals newer than 05 won’t fit the stock Kx body because they are 50mm bodies. If you can find an a-kit showa shock and/or shock body, then the 06+ internals will fit due to the larger 50mm a-kit body, but you will also need an a-kit adjuster which is a whole project to find in itself nowadays for those years of shock. You’re better off trying to find a complete working one.
Imo your best bet is what I first recommended, get an adjuster that has the hi/lo adjustment, or get a 2006+ kx250 shock if you want the whole thing. If you wanna get Showa for the simple sake of matching your forks, I would’ve probably gotten 2020 kx250f KYB forks and your life would be a lot easier than trying to sort through all of this.
djp48
Ludington, MI US
11/15/2021 3:59am Edited Date/Time 11/15/2021 5:55am
Thanks for taking the time. There is a lot of incomplete and misinformation out there.I am definitely taking everything into consideration.
I feel I got a fair price on both the forks and the shock so I don't think I'm in to deep yet. Theres definitely a market for the forks.
Figured it would be a challenge dealing with parts for the a-kit stuff.
We will see how the rm shock sizes up and everyone will know a little more. Looks to have the same body as the early rmz 450.
I've got a mill, lathe, welder, torches, press e.t.c. and don't mind a little challenge. Not looking to redesign the entire shock, but if its as simple as finding or modifying the clevis ill probably have a go at it.
Maybe it will slide right in?
DrewJett747
Belleville, IL US
11/15/2021 8:51am
Try to follow my thinking here for my 03.
So, I'm also going down the same path as you with my 03 (way different linkage set up). I recently saw a video on YouTube called $800 kx125 build (something like that) and they took a 04 KX shock and modified it to fit on an 03 KX and I've seen a few 04 KX's with a 18mm Showa RM shock on instagram. So, in my head, the RM shock can be made to fit on a 04, an 04 KX shock can be made to fit on a 03, so a RM shock could be made to work on a 03 KX with something similar done as the video shows.
In the video it looks like they moved the bottom bolt hole up on the clevis. Looks to be a simple mod and I've seen a few 04 KX's on Instagram with the Showa RM shock
I've had my RM shock for awhile now but haven't tried to dig into retro fitting it yet. ill need to bust out a set of calipers/tape and do a few fitment checks mainly on the shock body for travel. Check out the 15:50 minute mark in the video for the shock details.
https://www.youtube.com/watch?v=T9zsMYoC4zE
DrewJett747
Belleville, IL US
11/15/2021 9:01am Edited Date/Time 11/15/2021 9:05am
Just a few RM shock examples
djp48
Ludington, MI US
11/15/2021 7:07pm
Thanks for the inspiration and the photos to back what I'm trying to accomplish.
Every thing you said makes sense. Lucky you if thats all that has to be done to make it work. As long as the o.a.l. and compressed lengths match you should be good?
Keep me posted on your findings.
Kidkawie
ქუთაისი GE
11/24/2021 7:55pm
The answer to your question is in the 2nd post. Use an older KX shock with hi-lo and swap the clevis (chape is translated, means clevis)
If you redrill a clevis you have to be exact as the suspension linkage ratio will multiply any mistake by 3.
RussB
11/25/2021 12:22am
Just to add more info about the Suzuki shocks.... 04-08 RM125/250 shocks are the same dimensionaly as 2008-2017 RMZ250 and 450 shocks.
I own/have owned multiple RM and RMZ's over the years and have played around putting a 16 RMZ250 KYB in the 08 RM250, 15 RMZ450 shock in the 08 RM250, 08 RM250 shock in the 17 RMZ450, 08 RMZ Ohlins in the 08 RM250.
The KYB RMZ shocks require some minor modification to the top upper mount of the shock to fit into the RM frame but that's it, everything else is a direct swap.
So in terms of Suzuki suspension you have a lot of options. Personally I find the stock Showa shocks from the 04-08 RM and 08-17 RMZ450 to be very good shocks (on the Suzuki chassis anyway). The KYB is okay, and Ohlins is on par with the OEM Showa but generally costs a lot more so isn't worth the extra cash over an OEM Showa.
KVA_536
Alto, MI US
11/27/2021 9:08am
Does this apply to the ‘03?
holloway5
Auburn , CA US
8/15/2023 1:26pm
djp48 wrote:
I ordered an 05 rm125 rear shock. Looks the same as the rm shock used in a magazine build. Should have 18mm shaft and high low...
Did the 05 rm125 shock end up swapping over ?
Post a reply to: 2004 Kx125 Rear Shock Swap
