Brembo brakes on a Honda?!
GeoffB33
Edited Date/Time 11/15/2018 5:45pm
I’ve recently bought a CRF front end for my CR250 project and I want to put my Brembo front master cylinder, line and caliber on it. Has anyone ever mounted a Brembo front brake setup on a CRF? Any help would be much appreciated.
chuckdavies
Coventry GB
11/15/2018 7:51am
Geico ran Master cylinders for a few years; that's the easy bit. You'll need a custom caliper mount to run the caliper and i'm not sure anyone sells one.
Eleven10 Mods team ran Brembo SXS front and rear calipers etc years ago, but they ran on custom billet carriers.
Good luck, cool mod to make!
Markee
Suffolk, VA US
11/15/2018 2:29pm
Get in touch with Trick Engineering
I put brembo on my KX500. Anything is possible. I fabricated my setup, but I have seen Trick Eng on instagram posting custom brackets made to fit brembos
JMX247
Santa Clarita, CA US
884th
11/15/2018 3:04pm
Markee wrote:
Get in touch with [url=http://trickeng.com/contact/]Trick Engineering[/url] I put brembo on my KX500. Anything is possible. I fabricated my setup, but I have seen Trick Eng on...
This is the custom bracket that Trick Eng made for my 89 cr125. It was made specifically for a brembo caliper.
Zesiger 112
Pink Hill, NC US
11/15/2018 5:45pm
JMX247 wrote:
This is the custom bracket that Trick Eng made for my 89 cr125. It was made specifically for a brembo caliper. [img]https://p.vitalmx.com/photos/forums/2018/11/15/302686/s1200_3DD1BAD9_20CD_4265_B018_01402A0E93FF.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2018/11/15/302688/s1200_779A15F9_4649_4B42_B7F1_538958E297F3.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2018/11/15/302687/s1200_A7B86FB4_A5B0_4B19_B3CA_0CF11A74E0E0.jpg[/img]
How much did he charge? And did you have to provide dimensions? I have a complete brembo system I want to put on my yz
JMX247
884th
11/15/2018 6:05pm
I provided the fork legs, the hub with oversized disc and the brembo caliper. Clayton did all the demensions and work.
Post a reply to: Brembo brakes on a Honda?!
