Fruitland, ID
It seems like the Varg charger is very similar to the Alta charger. I don't have any experience with the Alta charger. Is the Alta charger 110V or 220V?
They are saying 2 hour charge time for a 6kWh battery. Seems like a 110V @ 15 amp wouldn't supply enough power for charge that size battery in that time period, but I'm just guessing...
For what its worth, with my Alta MXR and the rapid charger (240v), i go from 1/3 SOC to full (including about 5 min of balancing at the end of the charge cycle) in about 70 minutes. On 120v, you would expect about twice the time required.
Post a reply to: Stark Varg Charging? 110 or 220?
