St. Petersburg, FL
9/30/2020 7:31pm
GO TO LAST PAGE FOR CURRENT LISTINGS OF WHAT IS STILL LEFT π
Thanks!!!
9-27-20 updated:
VF3 - v-force Reed Cage Reeds $80
Triple clamps off 2007 yzf $30
.44 front fork springs $40
.48 front fork springs $50
4.9 Titanium rear spring $85
5.3 steel spring $35
PC shorty silencer $55
2009 yz450f swingarm $125
Sunstar MXR1 chain 120links new $45
Talon black Aluminum sprocket 48t $10 used
Sunstar New steel sprocket 49t $15
These will fit all Yamaha big bike hubs (yz125,250,250f,450f, wr, wrf) from 1999 to 2020.
02-14 style yz250 airbox with boot $25 (one chip in mount)
F & R Tire pair $40 (19β & 21β various sizes)
F tire $20
R tire $30
Used 02-15 yz plastics $10-$20 LMK what you need specifically
New blue fork guards 08+ $15
New Cyra stadium number plate $15
OEM clutch complete Basket, Hub, etc. $??? Offer
OEM clutch frictions & steels $??? Offer
Used Barnett clutch basket $??? Offer
Rekluse core manual torque drive clutch $??? Offer
Post your # or PM me for specific pics.
Will consider some trades.
Thank you!
Thanks!!!
9-27-20 updated:
F tire $20
R tire $30
Thank you!
Updated:
Complete race engine, rebuilt main bearings, water pump & seals, crank was in spec & still good, ported race cylinder with nice cross hatch, milled head (pump gas spec), wiseco forged piston, bolt on & go race!!! - $1150 free shipping!
Just the bottom end & tranny from above, no cylinder or head $700 free shipping.
Wiseco forged piston 8040m06640 $85
Boyesen Rad valve w/ like new reeds $80
Stock reed cage w new carbon fiber reeds $40
Lightspeed carbon ignition cover $120
NIB Carbon Fiber Works Carbon sprocket cover $25
Aluminum yz250 frame 2005-2019 $350 shipped to your local Fastenal. If you have a steel framed yz250 this is a great chance to go modern.
2006-2007 SSS forks $375
2006+ Shock $125
Above sss set $475
2005 AOSS forks $175
2005 Shock $75
Above set $225
2003 forks $50
2003 shock $50
Above set $75
Triple clamps 07 yzf $45
Triple clamps 05-06 $35
Triple clamps 03 yz $25
2003 swingarm & linkage $50
YZF silver OEM wheel set $300 2009 + 25mm rear hub size
YZF black OEM rear wheel $140 2009+
For the newer style 25mm hub size
DID 520DZ2 gold chain 114 links new in box $35
Talon silver 51t $30
NIB sunstar alum 50t $35
New black alum 49t $30
Used dirt tricks steel 50t $25
New steel sprockets 49t & 50t $15
These will fit all Yamaha big bike hubs (yz125,250,250f,450f, wr, wrf) from 1999 on down.
02-19 stock gas tank $75
02-19 subframe with airbox $100
just subframe $75
just airbox $40
Electronics (CDI & coil) from 2003 1999-2005 same) $100
FMF SST pipe $125
PC silencer $55
F & R Tires $40 (various sizes)
F tire $20
R tire $30
F or R 2003 rotors $10
Both rotors $15
Wave rear rotor $15
Used 02-15 yz complete plastics set $20-$40
New 2015+ style blue shrouds with new graphics $pending
Used 1 1/8 Bars $15
Boyesen clutch cover $pending
Seat & cover complete $20
06 front axle $10 with spacers $15
2010 yz450f Rear brake caliper, hose, master cyl, with new yzf style pedal $45
New Scott goggles $10 or I will throw them in for free with any spend over $150 π
Thanks!
Very fair price Passing because they won't fit my combination!
One off the 2010 yz450f swingarm
One off the 2003 YZ250 steely smoker
I can get you better pics when I get home if needed.
Thanks
Iβll split it with you if want them.
Shoot me your zip & I can get an estimate.
Thanks
Yes they are & sorry about that. They are from an 06 so you get the better head. LMK if still interested & I can send additional pics. Thanks ππ»
Shipping was $65.80 (25lbs to residential). I will eat the $5.80 if you can cover $30 of it. If you have a work or business address I could send it to that would also help me out if poss as well. It you are cool with that LMK & I can get them pulled, cleaned & boxed for you.
Thanks ππ»
I threw a used piston in there to show it is std bore & still tight
Thanks & let me know if interested still
Post a reply to: Nice YZ250 parts (2 stroke)
