Wanted RM125 parts
m1ke2001
Odenton, MD US
Edited Date/Time 7/5/2017 4:22pm
I need a rear shock and gas tank for a 2007 RM125. If you have any other cool aftermarket parts I would like to see those as well.
7/3/2017 5:06pm
I have a rear shock. It's been valved by factory connection. I have 5.3 , 5.4 , 5.5 and a 5.7 kg spring for it.
I also have a yellow Clarke gas tank 3 gallon .
m1ke2001
Odenton, MD US
7/3/2017 5:53pm
I have a rear shock. It's been valved by factory connection. I have 5.3 , 5.4 , 5.5 and a 5.7 kg spring for it. I...
Im quite afraid to ask how much for the shock but I would like to know and can you send pics as well with the gas tank. Also do you have a stock tank and does the 3 gal tank look different up by the cap? Does it stick uo further?
7/3/2017 6:50pm
125 shipped work for you for the shock?
The tank does stick up higher than stock. Not the best looking set up. It's for enduro races . I can get pix tomorrow if u want.
I don't have a stock tank. I do have a rear wheel from a rm250. Also a front wheel with axles and spacers form a rmz250 if u want to run rmz forks this is what u need. Wheels are 75 each shipped.
Also have a linkage knuckle and link arm from a 2007 rmz450 . It will bolt to rms . I was told that it would have a slightly more progressive curve than a rm knuckle. I never tried it though. $40 shipped
m1ke2001
Odenton, MD US
7/3/2017 7:06pm
125 shipped work for you for the shock? The tank does stick up higher than stock. Not the best looking set up. It's for enduro races...
I will take the shock, I guess I will skip on the tank since I ride mx but if you dont mind can I wait til after the 4th of july until wednesday or thursday maybe?
m1ke2001
Odenton, MD US
7/3/2017 7:07pm
m1ke2001 wrote:
I will take the shock, I guess I will skip on the tank since I ride mx but if you dont mind can I wait til...
Also is the stock spring on it?
7/3/2017 7:11pm
it's not the stock spring. Not sure what happened to it. I have a yellow 5.3 5.4 and a 5.5 or 5.6 . Also a blue rt 5.7kg.
No rush I'll be busy tomorrow too. Have a good 4th celebration!
m1ke2001
Odenton, MD US
7/3/2017 7:24pm
I am extremely light and I think running a lighter rear shock spring would be better but im afraid of throwing things off balance. Do you think you could put the next one lighter on their or what do you suggest? Also have a happy 4th too!
7/4/2017 3:39am
Gotcha. I'll put acouple different ones in there so u can change them up .
Thanks
m1ke2001
Odenton, MD US
7/4/2017 4:28am
Thanks
Ok thanks
Sam V
Brownsburg, IN US
7/4/2017 8:01am
I have a brand new set of 2006 engine cases
m1ke2001
Odenton, MD US
7/5/2017 4:09pm
Thanks
I sent you a PM back about the shock and springs that go along with it. If you were wondering the PM works through e-mail so check their.
m1ke2001
Odenton, MD US
7/5/2017 4:22pm
Thanks
m1ke2001 wrote:
Ok thanks
Oops, disregard that I just now saw your PM from earlier.
Post a reply to: Wanted RM125 parts
