Sacramento, CA
9/20/2020 7:42pm
Really confused. I have literally put this thing in hundreds of times and it won't go in no matter how hard I bang it. It's lined up in the hole as far as I can tell. The only thing I can think it's pretty dry (no grease with me) but I put some WD and oil on it. Anybody ever experience this?
Still no dice.It will even go in from the other side but not the correct side. No blowtorch to heat it up a bit and try and pry the receiving end open a bit. I'm camping at the track tonight and don't have everything with me.
If I kept the same 2004 RM running competitively through 10+ seasons of sand tracks I must know something about working on bikes. I rebuilt this one from the frame up and I'm restoring an 82 RM- just powdercoated the frame and now putting the bottom end together. Am I clueless half the time, yeah, but I try.
If the point is it got gouged at some point in 16 years of working on it- it sure did.
Check for burs
Does the axle slide through with out the wheel
Does the axle slide through the wheel
When you install the axle are you positive the big end is not catching the lug
The other half you ask ... repeat step 1 till complete.
Don't ask me to explain it.
The axle will even go through the other side unless it's also going through the wheel. It's the weirdest thing I have ever seen. Ah well, I wasn't meant to ride today. I'll keep trying. Maybe it's just not enough grease (don't have more with me).
"Inspect the spacer tube between the wheel bearings. It may have moved just enough to prevent the axle from sliding through"
Lol
Post a reply to: RM250 front axle bolt won't go in
