02 CR250 questions
JWACK
NM US
Edited Date/Time 11/14/2020 12:18pm
I just picked up a mint 02cr250 and want to do a decent build.
What the best engine combo? Can I use the better 03 cylinder on the 02 bottom end? What about reed cage set up? Will the newer 03 reed setup bolt on?
I wanted a 03-07 but this bike came up and it was to clean to pass up.
FGR01
AZ US
610th
10/7/2020 6:21pm
First thing is make sure the horrible stock airboot to airbox seal setup is not still in place. If it is, replace it with the Twin Air Sealing ring kit or the MX Bonz kit if either is still available.
JWACK
NM US
10/7/2020 6:48pm
FGR01 wrote:
First thing is make sure the horrible stock airboot to airbox seal setup is not still in place. If it is, replace it with the Twin...
It has the mx bones setup on it already! That’s the first thing I looked for. Woohoo
yz133rider
Avondale, PA US
10/7/2020 9:13pm
Send it to pro circuit or Tom Morgan would be my suggestion engine wise!
omalley
Snohomish, WA US
10/8/2020 6:24am
What about Varner? Heard good things...Laughing
In all seriousness, I had TMR do mine and was impressed with the bike and in my dealings with Tom. True stand-up guy and an encyclopedia of two stroke knowledge.
I have heard good things about what PC can do with these as well.
I wouldn’t worry about 02-03. Slight difference but nothing earth shattering. Have a good tuner do the head and porting and they rip.
I would advise picking up a spare cylinder and power valve if you run across one, since they’re getting hard to find. There are slight differences between 02, 03, and 04 power valves, so make sure to have that years set. 05-07 was a completely different cylinder and power valve.
omalley
Snohomish, WA US
10/8/2020 6:27am
Forgot to mention...when/if you get into the bottom end, ditch the stock crank and use the OE 05-07 crank. Drop in mod and gets rid of the steel shells that can potentially crack and unwind, taking out the cases, etc etc.
JWACK
NM US
10/8/2020 8:21am
omalley wrote:
Forgot to mention...when/if you get into the bottom end, ditch the stock crank and use the OE 05-07 crank. Drop in mod and gets rid of...
10-4 on the 05-07 crank. I have one in my shopping cart already!
I know H4L on here knows the ins and outs of these early case reed bikes. Pro circuit Or Tom Morgan may be an option. I usually do my own porting as I’ve seen some questionable work from bigger shops.
crc245
Yorba Linda, CA US
10/8/2020 9:23am
Keep an eye on the RC valve electronics: believe the motors can go bad in the wrong environment. 05-07 base gasket is a direct bolt on and it helps lower the excessive squish seeing it's thinner. Those 24mm clamps are solid on the Gen3 chassis, and any Honda CR/CRF 47mm twin chambers fit if you'd like the newer 2004+ brake hanger/fresher units/want to swap. Wheels from 2002-2012 (2013 CRF250 too) fit right on, and the 2005+ rear hub is lighter than the 2002-2004's (significantly). 38mm Keihin PWK swap is a popular mod, just be sure to get the long body/screw top for any 2002/2003 application. If you run the Mikuni, swap the needle jet to an S7 and replace the jet block gasket to get it closer to proper. Lots more options, but that should be a solid start. Congrats on the project!
erik_94COBRA
Houston-ish, TX US
10/8/2020 12:49pm Edited Date/Time 10/8/2020 1:15pm
On my '03, I was pretty happy using the thinner base gasket from the '05+ CR250 on the stock cylinder. This reduced port timing a small amount and decreased squish while staying in an acceptable range (0.065" stock, 0.055" with thinner gasket).
Eric Gorr has a Tech Tips article for free on his site for the '02-04 CR250. From what I recall, it basically cut the base by 0.030" and raised the exhaust port by 0.060". So you'd get more low end from the base cut and have it pull farther on the top end from raising the exhaust port. Based on my experience with shifting the gaskets around, I think this would work pretty well for cheap. I also had an '05 CR250 with the base cut and head opened up to match. It was super crisp from the bottom through the midrange, but fell off a bit on top.
The TMX can be finicky without proper squish. Hence why many went to the PWK. The PWK is really set it and forget it though. I ended up liking the TMX on my '05 better after the head was modded.
I had a V-Force 3 reed valve on my '03. Minor improvement.
Brakes: braided steel lines improve feel front and rear. Oversized rotors are hard to find for the '01-'03 due to the different caliper bracket bolt spacing. An oversized rotor on my '05 made the brake performance close to KTM levels.
Forks: '02 still used the 20mm base valve pistons, but still aren't bad. Springs and maybe revalve should have them working good.
Side note: I have a Gnarly pipe and Turbine Core silencer from my '03 still. Will sell super cheap if you're interested.
Edited to add: some epoxy in the transfer ports also helped in the low to mid transition without impacting top end much. I did this on the ‘03 cylinder I had.
Lots of other useful info on the Honda 2-stroke forum on TT.
JWACK
NM US
10/8/2020 6:58pm
crc245 wrote:
Keep an eye on the RC valve electronics: believe the motors can go bad in the wrong environment. 05-07 base gasket is a direct bolt on...
Lots of good info here! Thank you!
JWACK
NM US
10/8/2020 7:03pm
On my '03, I was pretty happy using the thinner base gasket from the '05+ CR250 on the stock cylinder. This reduced port timing a small...
Thanks! I’m going to try the 05 base gasket right away. That sounds like easy money right there.
I’ll pass on the gnarly setup. One reason I’m building one of these older Honda’s is to have the top end performance. That’s something the newer ktm/husky just doesn’t do very well.
10/9/2020 12:15pm
I had an '02 for a while and I think I went with the '05 up intake manifold, with a Boyesen Rad valve and '04 and up air boot but that was later on. Then a Keihin short body PWM and Boyesen exhaust spigot with cylinder porting and head mod. I raised the exhaust port .020", did a lot of matching and had it re-plated. I think took out about 0.3 cc and set the squish at about .042" with a .012" Cometic base gasket.
Remeber doing a lot of stuff with the PV. Very picky about the set if I remember right. Made a little stop limiter that I thought worked really well, but I don't remember the details. I do remember I got to were I would never clean them if the moved smoothly because I thought they sealed better with carbon filling up all the cracks. I know it ran better with dirty PV's.
Tried a sorts of pipes and ended up with the stock pipe and silencer. And YES, you have to have a sealing ring for the air box, but you've got that.
flat4
N.E., PA US
10/10/2020 3:55am
Had an 03. Tom Morgan 100% in my experience.
omalley
Snohomish, WA US
10/10/2020 6:41am Edited Date/Time 10/10/2020 6:43am
JWACK wrote:
10-4 on the 05-07 crank. I have one in my shopping cart already! I know H4L on here knows the ins and outs of these early...
I’ve heard a few rumors of PC’s hired help butchering the port work awhile back but no first-hand experience. I went with Tom because of that, plus the fact that PCs attitude seemed like they weren’t interested, vs Tom immediately replying and engaging in discussions of what I was looking for, etc. His work was beautiful. I wish I had pics. The face of the power valves were like a mirror. Port work was flawless and he was always available for questions.
Nothing in here should dissuade you from PC. H4L had a very good experience with them and the bike reportedly ripped. I just got a vibe I didn’t like and went elsewhere.
Sadly, Varner was magic with these from what I hear, but based on the other thread here, his customer service has been such a train wreck that I wouldn’t risk my cylinder there.
Tom does deck the cylinder, so if you’re after a mid-up motor make sure to discuss that with him. I told him I was an out of shape Vet C/B rider and didn’t want to have to ride it like a 125, so I believe he tailored it more towards the fat old guy end of the power curve, lol.
H4L
10/11/2020 12:03pm Edited Date/Time 10/11/2020 12:29pm
JWACK wrote:
I just picked up a mint 02cr250 and want to do a decent build. What the best engine combo? Can I use the better 03 cylinder...
You can run the 03 cyl. on the 02 bottom end. I've spoken to a couple of reputable tuners about it through the yrs..
They've commented that the 03 cyl. has the best oem porting specs & platform to work off of. After tuning these bikes & owning them since 03 these have been my findings as well. Have owned many 02,03,05,06 & 07 models & the 03 cyl. is my favorite.
I've been running an 03 PC cyl./ head & reed cage combo on an 02 bottom end since 05 with very good results.
H4L
10/11/2020 12:23pm Edited Date/Time 10/13/2020 9:45pm
Not sure if you've seen this vid posted recently, but it shows the CR pulling the ESR YZ325 of MA800 going up one of the GH Hills. IDK if the #200 rider on the CR has a bigger bore than a 250cc engine or what mods have been done. Either way it's impressive how the CR case reed makes very good power with the right mods.. I believe JG33 was in 3rd on a case reed CR as well.
It's at the 4:40 mark.
https://youtu.be/nPw8thCyXHw?t=280
JWACK
NM US
10/11/2020 1:18pm
H4L wrote:
You can run the 03 cyl. on the 02 bottom end. I've spoken to a couple of reputable tuners about it through the yrs.. They've commented...
I will have to track down this setup. Do you run the 02 ignition and intake as well?? I’m also finding it hard to find the 02 specific exhaust. The 03 and up are a lot easier to find.
JWACK
NM US
10/11/2020 1:28pm
H4L wrote:
Not sure if you've seen this vid posted recently, but it shows the CR pulling the ESR YZ325 of MA800 going up one of the GH...
I was there! I didn’t ride pro class but I watched it. I’m actually building this bike for next years 2stroke nationals. I rode my 08 rm and it was just a bit nervous for me when it got rough going down the hills. I almost got a holeshot in the over30 expert class though! Stupid me couldn’t shift under a load and I lost it. I’m on the 351 Suzuki. Without riding much it was brutal. So I want to get this Cr built and go back in better shape on a bike I can push more comfortably.
Thanks for the info!
40
WY US
10/11/2020 1:31pm Edited Date/Time 10/11/2020 3:09pm
omalley wrote:
I’ve heard a few rumors of PC’s hired help butchering the port work awhile back but no first-hand experience. I went with Tom because of that...
We have sent several 05-07 cylinders and heads to PC over the years and the results have been very good at fairly reasonable prices.
They have a cookie cutter engine setup where the only options offered to choose from are a pump gas head, or race fuel head. No other options are available.
PC does not mill the cylinder base, and does not use epoxy in any of the ports or transfer tunnels. These engines run well and are a good value for your money. Big improvement over stock.
However, overall customer service, and their unwillingness to answer detailed questions or offer any setup help are definitely NOT PC's strong points.
Conversely, Morgan offers some of the best customer service in the business. Quick to respond to inquiries, and willing to offer customized options based upon the needs of each client, he's top shelf on service.
WY US
10/11/2020 1:36pm Edited Date/Time 10/11/2020 1:42pm
JWACK wrote:
I will have to track down this setup. Do you run the 02 ignition and intake as well?? I’m also finding it hard to find the...
The 03 ignition is reportedly better than the 02 if you can find one.
We e-mailed JD ignition in Italy a few months ago and they were offering a double map 05-07 iginition. Didn't inquire about 02-04 but they're worth contacting.
H4L
10/11/2020 3:04pm
I’m running an 03 JD ign. with an 03 intake as well. Like 40 mentioned the PC mods are a great value for the gains that the engine produces.
JWACK
NM US
10/11/2020 3:18pm
H4L wrote:
I’m running an 03 JD ign. with an 03 intake as well. Like 40 mentioned the PC mods are a great value for the gains that...
Thanks again. I will try and track down some 03 parts and send them to PC.
JWACK
NM US
10/11/2020 3:23pm
40 wrote:
The 03 ignition is reportedly better than the 02 if you can find one. We e-mailed JD ignition in Italy a few months ago and they...
I just sent jd an email. Thanks for the info!
H4L
10/11/2020 3:40pm
IDK if PC still has the software to program the JD ign. like they use to. They use to be a US authorized distributor when I picked up the 03 ign. from them in 05. PC programed it with a custom map to compliment their engine mods.. The combo is very good on VP C12 fuel.
JWACK
NM US
10/11/2020 4:09pm
H4L wrote:
IDK if PC still has the software to program the JD ign. like they use to. They use to be a US authorized distributor when I...
Want to sell yours??? Woohoo Woohoo Grinning Silly
But in all seriousness I will just have to see what jd says. I can’t ride the bike to its potential with the stock ignition anyways so I’m sure it would be fine. I just like shiny things that go braaapppp!
H4L
10/11/2020 5:54pm
JWACK wrote:
Want to sell yours??? :woohoo: :woohoo: :lol: :silly: But in all seriousness I will just have to see what jd says. I can’t ride the bike...
If I ever sell the JD ign. I’d more than likely sell the entire combo.. Cyl, head, Doma exhaust since it’s such a good engine package. What I like about the JD ign. it allows the engine to rev faster & freely. It’s just one piece of the puzzle to help the engine run optimum. I haven’t tried the 03 oem cdi, but I’m sure it will run fine.
erik_94COBRA
Houston-ish, TX US
10/11/2020 9:05pm Edited Date/Time 10/11/2020 9:13pm
JWACK wrote:
Thanks! I’m going to try the 05 base gasket right away. That sounds like easy money right there. I’ll pass on the gnarly setup. One reason...
Edit: can’t seem to send PM. Send me one and I’ll reply.
H4L
11/13/2020 1:04pm
Hey H4L did you put your 02 power valves in the 03 cylinder or is it 03 every thing?
Hey Rich - Just seen your PM as well. I would highly recommend that use the corresponding PV's that go to the yr. cyl.. Honda changed the cyl. oem porting specs each yr. in 02, 03 & 04 & also redesigned the PV's.. It's crucial to get a good seal when the PV's are closed in the exhaust port. That translates to a better off idle throttle response & lowend power in the lower rpms part of the powerband.
DM268
Princeton, MN US
11/14/2020 12:18pm
I’ve had my 03 cr250 for almost ten years now and I bought a lectron carb and it was the best investment I’ve made on the engine. I used the pwk for awhile and it definitely helped but the lectron has been great.
Post a reply to: 02 CR250 questions
