Lake Elsinore, CA
Has anyone heard of the ring hitting the powervalve or am i just that unlucky? The top end only had 6 hours before this happened, it scarred the cylinder pretty bad but luckily the part of the ring that broke went into the pipe. Is there something i should check when i finally get it back together or was it just a rare thing?
I don't think it hit the power valve. I bet your ring end gap was not set correctly or not at all. It needs to be set correctly AND filed evenly. If not, it does not have any relief when compressed, or it will have uneven relief (buy a ring end file), and it will drag on the cylinder wall and catch on the exhaust port..........SNAP. Also make sure the ring is not in upside down. There's a top and a bottom to the ring. Also there a notch on the piston where the ring ends go. The ring MUST be on there. This is to prevent the ring from rotating while on the piston and letting the end of the ring from catching on the exhaust port.
I'm betting one of these was the cause, not from it mysteriously catching the valve.
Get a new cylinder and new piston, correctly set your ring end gap with a ring end file to the correct specs in your service manual. make sure the ring is not in upside down, and end gaps are in the notch. It should run like a well oiled top.
Good luck.
Another good video about 2 stroke piston rings. You have to make sure the ring ends are on the pins on the back pins. It prevents the rings from rotating on the piston and catching on the ports. You don't have this with 4 strokes. 4 stroke rings can float around.
https://www.youtube.com/watch?v=xyedUaK4hmI
2 strokes are really basic, but there's a couple critical steps.
Post a reply to: 2016 Ktm 150sx
