Eagle Grove, IA
2568th
Was wondering if anybody had a wiring diagram or shop manual information to help me out.
Currently my map switch stays lit when bike is off I’ve been trying to chase wires and checking connectors but I’m not sure what they all are. I’m trying to avoid cutting open my whole harness just to keep it looking clean. So far I know that my map switch is good since I swapped it with my 250 and still have same issue, my ecu is unplugged and it still stays lit so I don’t believe it to be that. There is a relay in the air box that I can unplug and the map switch goes off so obviously it has voltage there when it’s not supposed to but I have no idea what this relay is for or where it even goes or comes from
I have the same issue on a 250 2017. Have swapped Voltage Reg, ECU, cleaned all the plugs I can find and still the Map Switch stays on.
This might help: https://www.advrider.com/motorcycle-electrics-why-use-relays/
Ricks is also extremely helpful: https://ricksmotorsportelectrics.com/blog/category/how-to/
Post a reply to: 2017 fc450 wiring issue
