805, CA
5/9/2022 3:57pm
Anyone know the correct part # for husky/ktm upper shock bearing? Everywhere I look says part # is r12025 for
my 2017 FC350 but the the inside diameter for the bolt is larger. Also has a foam seal instead of rubber seal on the outer bushing. Thanks for the help
ID of new bushing is 12mm
OD Of both bushings is the same as well as ID of both bearings. Old bushings have rubber seal attached. New bushing has separate foam seal.
I was able to reuse the old bushings but they weren’t removed with the intention of reinstalling. They are runable for now but would rather replace them.
I have new 10mm parts if you need them
Post a reply to: 2017 ktm/husky upper shock bearing?
