Hey guys, looking for some insight on my 2018 250r, I started it up this morning and it ran without any issues, I turned it off and then tried to turn on again but nothing except some pops and 1 backfire, I tried this several times but nothing worked, I thought it was flooded so I pulled the plug let it dry out and made sure I had spark, both were good.
I made sure all connections were solid however after several hours of diagnosis I am at a lost, some insight regarding this would be great.
Bike is completely stock, no rebuilds and only 30 hours.
This Is what I have done so far:
Fuel Injector is working as it should
Fuel Pump is working,
I have spark,
Air filter is clean and not over oiled
Bike does not want to fire at all, will crank rapidly and battery is fully charged and does not drop below 11v while cranking.
I have tried to spray quickstart down the intake however nothing happens,
I have compression.
I have disconnected the kill switch to see if it would start however nothing changes, still cranks and has spark. MIL does not indicate anything and boots like normal.
Could valves be the issue? It ran fine a few hours prior to this happening.
Any insight regarding this would be helpful.
I have spark,
I have compression.
https://youtu.be/wxfwJfioLEQ
Did it end up being the valves needing shimmed? Mine is acting the same exact way and I've replaced every part you've listed as well. Went through the same process you have and so I'm going to check the clearances tonight and make sure it hasn't jumped timing as well.
Post a reply to: 2018 CRF250R, Problems with starting engine, will not start.
