'22 CRF450R Hydraulic Clutch Help
moto593
Prior Lake, MN US
Edited Date/Time 5/26/2022 7:55am
Hey guys, I post about this last week and I'm still having trouble. I put a steel braided clutch cable and Cerakoted my clutch master cylinder. Someone in the process of this I screwed something up. It feels like my pushrod is too short. Everyone kept saying that I had air in the line but it seems like it's something else. My clutch lever is stiff and the full travel of the lever feels normal, yet the clutch isn't disengaging enough to freely spin the rear wheel in gear. I think the pushrod isn't sticking through this mounting bracket far enough. (I never took my clutch cover off but I did pull the pushrod out a couple inches and put it back). Any ideas guys?
willbilly
Corpus Christi, TX US
5/21/2022 12:39pm
Pull off clutch cover and see if the pressure plate moves. Should be noticeable. When I replace a hydraulic line it is always difficult to bleed. Did you try reverse bleeding from slave cylinder using a syringe?
moto593
Prior Lake, MN US
5/21/2022 1:47pm
willbilly wrote:
Pull off clutch cover and see if the pressure plate moves. Should be noticeable. When I replace a hydraulic line it is always difficult to bleed...
I pulled the cover off and you can see the pressure plate move about as much as the pushrod is sticking out with that slave mount pictured. The rear wheel will turn if I apply pressure and the clutch roughly disengage but it won't freely spin. I'll check my 2016 too and see what the difference in pressure plate throw is.
I tried to vacuum bleed, feed with syringe, pump-hold-crack, but it always ends up back at this point with the clutch lever feeling normal but not enough disengagement to spin the rear wheel.
moto593
Prior Lake, MN US
5/21/2022 4:18pm
Factor E wrote:
Is that a Rekluse system?
Nope, stock slave cylinder and clutch. I did buy a Rekluse slave cylinder to swap out and it feels the same.
FGR01
AZ US
697th
5/21/2022 8:21pm
On many bikes you cannot spin the rear wheel by hand even when the clutch is 100% due to some drag that still exists.
Have you tried starting the bike and putting it in gear and seeing if the bike stalls or creeps due to clutch drag?
Wolfey
IL US
5/22/2022 7:03am
FGR01 wrote:
On many bikes you cannot spin the rear wheel by hand even when the clutch is 100% due to some drag that still exists. Have you...
Yeah not sure if this helps but my 21 Crf450r rear wheel will not spin with clutch pulled in.
moto593
Prior Lake, MN US
5/22/2022 8:58am
Lmao my 2016 is the same way I guess. Can't believe I didn't notice that. Im putting things back together now and will update soon.
Colgate, WI US
5/26/2022 4:51am
It's Good?
moto593
Prior Lake, MN US
5/26/2022 5:16am
526 wrote:
It's Good?
Lmao yes it worked the whole time. Just a bad test method Laughing
mshea397
Prior Lake, MN US
5/26/2022 7:20am
too much time reading engineering textbooks. just kidding. glad you got it figured out.
moto593
Prior Lake, MN US
5/26/2022 7:54am Edited Date/Time 5/26/2022 7:55am
Yeah thanks Mike, like I wasnt embarrassed enough 😆
Post a reply to: '22 CRF450R Hydraulic Clutch Help
