Athena YZ300 kit
FahQ
NJ US
Edited Date/Time 12/30/2019 7:38pm
Anyone have a similar experience with the Athena 300 kit?
I stopped by my buddy was bolting this thing up.
As I started to look closer I was like WTF
The little crescent of light is the space between the ring and the bore
This is where the guy doing the chamfering of the ports had a brain fart
This is the most bazaar part, the head has a raised section about .2mm high and 10 mm wide.
What are your thoughts!
(Oh yeah I know the esr guy just took his shirt off)
DynoDan22
Victorville, CA US
12/30/2019 1:08pm
That has to be one of the worst finishes I've seen on a two stroke cylinder. The 310cc cylinder that Ray Charles ground for me was only marginally better. Not to be a dick but no way I'd run that cylinder. This will result in nice metal chunks whirling around in your bottom end and a wrench rabbit rebuild kit no doubt. good luck!
cwtoyota
Tacoma, WA US
12/30/2019 5:06pm
FahQ wrote:
Anyone have a similar experience with the Athena 300 kit? I stopped by my buddy was bolting this thing up. [img]https://p.vitalmx.com/photos/forums/2019/12/30/395023/s1200_417CAA88_5DAC_4CCB_8E96_D19B08E5C872.jpg[/img] As I started to look...
That's not from chamfering the ports, it's actually a casting that didn't clean up when it was bored during the machining process. The Machinist didn't catch it, and neither did the plater or the inspection department...
You should send that back, it's junk.
FahQ
NJ US
12/30/2019 5:33pm
cwtoyota wrote:
That's not from chamfering the ports, it's actually a casting that didn't clean up when it was bored during the machining process. The Machinist didn't catch...
Yeah I think it's going back.
I was looking at that defect thinking it looked like a grinding bit just sat there before it was plated.
Then they just passed it down the assembly line thinking the plating would fill it in.
Post a reply to: Athena YZ300 kit
