Cylinder Wall Damage SX 125
Zalev
Glogow PL
658th
Edited Date/Time 4/22/2021 7:04pm
This cylinder was replated 20h ago, what could cause that?
sandman768
Saratoga Springs, NY US
4/22/2021 12:30pm
Pull it apart & find out, need to inspect piston and upper & lower crank bearings.
pete24
Marlborough, MA US
4/22/2021 3:41pm
is that aluminum stuck on there or is it a gouge? theres also a lot of wear on the exhaust port i think it dirt related
Mx746
Marietta, GA US
4/22/2021 7:04pm
once you pull the jug you may find a chunk of ring missing if it spun and caught the port, as mentioned above, if gap is too tight, as the heat causes rings to expand the ends touch, the ring continues to expand and walk out of the groove, it can then migrate over the locating pin and turn, and catch a port.
Zalev
Glogow PL
658th
4/22/2021 11:04pm
Pipe is leaking a bit where it connects to the engine, I was using pressure washer pretty hard at this place, maybe some dirt went into the cylinder that way..
Post a reply to: Cylinder Wall Damage SX 125
