Elk Grove, CA
6/27/2018 12:20pm
So i split the cases on my 98 yz250. I got the crank bearings out since I’m replacing those. I now want to clean the case halves really good. It was a pain in the ass removing the crank bearings but I did it since I’m replacing them.
Can I get away with Leaving the other bearings in if wash the case halves with some soap and warm water. Followed by compressed air wd40 etc?
I don’t want to damage the bearings trying to pop them out.
GoYamaha
The red arrow is pointing to #2 (part 93306-20540-00)
And the green arrow is pointing to #24 (part 93306-20562-00)
On this schematic
https://www.ronayers.com/oemparts/a/yam/50043f10f8700209bc78e024/transm…
Correct?
Also I’m just using Ron Ayers for the parts numbers. Does anybody know of a cheaper place online?
Thanks
I have never had a bearing that checked out good during disassembly go bad in in transmission so take that for what it's worth. I have done more bottom end rebuilds than I can count and try to do the best job I can within budget constraints of whomever the owner is............
Post a reply to: Do I need to remove all bearings before cleaning crank halves?
