Fc450 hydraulic clutch issue
DB97
Orlando, FL US
Edited Date/Time 5/23/2017 1:24pm
I'm working on my friends bike after his clutch lost pressure on his 2nd ride on the bike. The master cylinder was empty so I know it's leaking after refilling multiple times and seeing it empty. I didn't see any leaks so we pulled the slave cylinder off and when you pull the lever it leaks around the plunger on the inside of slave cylinder. I'm assuming it should be self contained and this is the problem but I didn't see a rebuild kit for husky and the ktm brembo cylinder is half the cost so before we order the ktm version just making sure this is the fix. In the picture it leaks from under the black seal that surrounds the plunger.
sandman768
Saratoga Springs, NY US
5/23/2017 9:48am
I had a problem with my clutch while down in Fla over the winter. Brought it to WMR in Stuart. The mechanic repaired it on his lunch hr while I waited...he then came out & said " you have a hesitation off idle, do you want me to fix it" I said sure.....30 mins later the bike was done....clutch fixed, remap & instant throttle response! I don"t remember the mechanics name, young kid, but I would not hesitate to go back there for service...I think my bill was 100.00-125.00, but the remap was worth that alone....
DB97
Orlando, FL US
5/23/2017 1:24pm
Thanks I'll let him know
Post a reply to: Fc450 hydraulic clutch issue
