Powell, WY
Needing help with jetting issues.. Currently riding a 2004 RM250, and I recently installed a Pc Works pipe with an R304 Shorty Running on 91 mixed at 40:1 using Castor 927. For elevation I'm at 5,000+ ft. Issue I'm having is the bike tends to bog On hill climbs, wide open, etc. I know changing jetting is crutial when changing out pipes but I don't know where to start
Sounds like you may be a little lean
Pro Circuit Jetting
Pilot jet: 48
Needle: NECJ, Clip 2
Also reinstalled factory pipe and fmf muffler, same bog
There would be no harm in going to the middle 3rd clip and seeing how it runs.
Your main is also a touch lean. I ran 168/170 in my RM, but then I am in a different country with different fuel etc to you so hard to say.
But as above, I would start with your float level. Use your manual for instructions and the correct measurement to set it too.
My current jetting is (stock just 1 clip leaner):
168 Main
48 Pilot
NECJ Needle
Clip position 2
I did notice my bottom end is a quite a bit less reponsive than before with the stock system. Not sure if this is from the 10oz FWW, turn my idle up, or drop my pilot jet 1 size.
You will need to make jetting changes to suit the Pro Circuit system, I went 2 main jets leaner when running a shorty silencer as opposed to the long stocker.
I'd definitely recommend trying a 45 pilot
165 and 45 as recommended in the kit
05 rm 250
Pc pipe, v3 , non shorty pc
110 purple and 927 @ 32-1
Runs perfect no spooge
Fresh plugs, buy extra for your tool box
Checked my float level and it was in spec. Dropped in a 162 main, a 45 Pilot, and needle on P. 2 Bike is running alot better. Thanks for all the help and input
Hope that helps.
Post a reply to: Jetting help '04 RM 250
