Marzocchi Inverted Fork Question
threefiddyone
Baton Rouge, LA US
Edited Date/Time 6/21/2020 5:57pm
So this is kind of a shot in the dark, but Im kinda lost on what to do. So when pitbikes were super popular back in 2007 I got some marzocchi inverted forks for my CRF70. You can see them in the attached picture, and Ill take better pictures when I get home. They are leaking and I need to replace the fork oil and seals in them. I just have no clue which model they are or any info besides the fact that they are marzocchi forks. They have about 8 inches of travel, and I believe are 35mm (not sure, Ill measure them soon). They were the popular mac daddy marzocchis that everyone was buying for their KLX110s back in the day. I vaguely remember that they are similar or are the same forks that KTM uses on the SX65s.
Do any of you guys know if these are the same forks that are used on the KTM SX65s? That would be really easy, since I could just order the fork seals off of motosport.
Also, which weight oil and how much oil do they need?
Are there any good guides to replacing the oil and seals for these forks, or are they pretty much the same as big bike forks?
Thanks in advance.
Holeshot922
Joshua, TX US
6/21/2020 5:53pm Edited Date/Time 6/21/2020 5:54pm
Ktm 50 seals, I use the upgraded skf brand. I run 20wt oil (200lbs). .52 springs and valving setup by PC.
Post a reply to: Marzocchi Inverted Fork Question
