Athens, GA
10/18/2021 10:54am
One of my bikes still has a cable clutch - who makes the absolute smoothest, minimal friction clutch cable? This is for a 2007 KX250 smoker.
For 10+ years now I've been running the Motion Pro Terminator T2 (not in production anymore?) and T3 Slidelight clutch cables. They've been pretty solid. I will say they don't seem quite as smooth as they were a while back (I think they were 100% Teflon lined before if I am not mistaken)
https://www.motionpro.com/c/t3-cables?v=12384
I've had Motion Pro make me special cables, too, so keep that option in mind.
They are lubed from the factory, but when they need a refresh, I use Tri-Flow lubricant. This has been the best cable lube I've found to date:
https://www.amazon.com/Tri-Flow-TF20006-Superior-Lubricant-12-Ounce/dp/…
I also use this Motion Pro cable luber that has been good as well:
https://www.rockymountainatvmc.com/parts/motion-pro-cable-luber-v3-p
Lastly, premium clutch perch assemblies like the Works Connection Elite and the ARC RC-8 are going to optimize the feel of the clutch system and make the pull even smoother (and it will stay that way).
Lastly, lastly, I happen to run the Wiseco forged baskets, too, and they do help with clutch cable smoothness, so my guess is that you're about as well set up there as you can be.
A couple of tips with your new Magura:
(1) The "C-lever" is AMAZING on hydraulic clutches. TRUE 1-finger pull. Check it out here:
https://www.midwestme.com/clutch-levers/mme-products/clutch-levers
(2) If the clutch starts acting up at all, stop immediately and check the hydraulic cylinder's shaft for binding/full return. I had one of the earlier "JACK" systems on my CRF450R and it locked up and wouldn't return. Magura's tech was great to talk with, but I'd already ruined a clutch pack, and if I remember right, a WORCS race. I went back to cables after that and never went back. My guess is they've come a long way and you'll have no problems, but just watch it closely initially.
I've had hit and miss experiences with the Magura units giving much lighter clutch pull over the years when people would request them in my shops. The Midwest ME lever that Rider5820 suggested is DIALED. I ran them on my last two KTM bikes.
For sure they were "blame-y," but ignore it, they need to cover their butts legally and that's how they are taught to respond to calls/inquiries (they are no Rekluse, that's for sure --- Rekluse is AWESOME "got your back service"), but the product really does seem ironed out now. I stopped using mine because I no longer trusted it, but if I got a good deal on one again, I'd try it.
FWIW, the tech I worked with was "Peter" I believe. He was technically competent, for sure. But again, for liability reasons, they feel they need to take a certain stance (that's Exec Mgmt's call - but not all companies choose Magura's stance). It doesn't mean their product is bad necessarily.
There are 2 choices, right? Assume the best in people or assume the worst. It seems they are the latter. And possibly that came from getting burned too many times by dishonest people OR they really did have a quality problem OR ... on and on.
https://www.rockymountainatvmc.com/parts/magura-hydraulic-hymec-clutch-…
Amazon's ratings are not as encouraging, so buy it from RMATV. They'll have your back.
https://www.amazon.com/product-reviews//B00M9MWTGK/ref=acr_dpx_hist_1?i…
One more recollection/data point:
I had the Magura HYMEC on a 2006 YZ250 2T with the MME lever and a Rekluse Core EXP clutch installed. I recall that being a "no no" setup for the Magura clutch per some website ... but guess what? IT WORKED AWESOME.
"clare m.Verified Purchaser
Location Wamsutter , WY, US
Huge improvement over an old hard to modulate cable system,
Like having a new bike
Spacers included did not provide correct free play for 06 KX 250,I had to stack both and stabilize with a clamp"
Ordered direct from Magura. They had to lightly modify kit number 2100363, and I needed additional mounting kit 2701697.
Magura said if they get another 05-07 KX250 order like mine, they'll officially make a new part number and offer it as a ready-purchase kit.
It will be interesting to hear what Magura says about this. This is definitely a new JACK failure mode to me.
They think it may have been an assembly issue, where the rod wasn't fully threaded into the piston. They are sending me a new slave cylinder and bleed kit.
Super satisfied with their customer service.
Post a reply to: Smoothest clutch cable brand? Or should I go Magura Hymec??
