Oregon City, OR
4/17/2018 8:59pm
Hello.
05 RMZ450.
I just purchased the bike. I took the top end of to replace valves, piston, etc. I noticed (after i tossed the old valve seals) that a intake guide has been replaced at one time. It is it more tapered where the seal is pushed on vs squared off like stock. Stock seals are wobbly and dont feel like they are on properly. By looking at the pics, any idea what brand/model it may be off? Id like to avoid replacing it. All of the seals i took off were sealing and were on tight. They all looked the same. Stock guide is on bottom in pic and is Flat on top. Thanks in advance
05 RMZ450.
All I could think is maybe Kibblewhite has info. (Do they make guides and seals?) And/or you got all intake seals when you need the smaller exhaust seals for those particular guides...???
I looked at kibblewhite and their measurements.. i think i will try and contact them ..
I also took a pic with a mirror through the window in the head..
maybe the steel valve seal if it is that kind of seal worn it out and rub the guide down ? or the retainer was bottoming out on the seal making it ware ?
if every thing els is ok have some one replace that guide re cut the seat good to go 60.00 includes the guide
best bet would just re place it and re cut the seat if every thing checks out
Thanks for the time.
Post a reply to: Valve Guide Info
