Kx450f Motor Zero hours
ge217
Vero Beach, FL US
Edited Date/Time 11/17/2015 7:46am
Asking $2700 obo
2012-2015 motor (believe it will fit 2009-2015).
Motor was a 2012 but was completely rebuilt this year and has not been used since.
~New cases
~Crank
~Valves
~Valve springs
~Valve guide seals
~Cylinder
~Piston and rings
~Main bearings
~All trans mission bearings due to new cases
~Transmission shafts
~All but 3 transmission gears are new
All oem parts, motor does come with wiring harness as well.
ge217
Vero Beach, FL US
10/13/2015 5:06pm
ge217
Vero Beach, FL US
11/16/2015 2:04pm
bump
cmotodad
Yorba Linda, CA US
11/16/2015 7:18pm
I the frame getting ready for a K5?
ge217
Vero Beach, FL US
11/17/2015 7:07am
No. This is just a spare motor. Last time I did a conversion it didn't go well. Scared to do and ride another one. If I did offroad only I probably would but not since I would ride it on moto 95% of the time. I was lucky enough to walk away from it once don't know if I would be that lucky if it happen again.
WileCyot
Katy, TX US
11/17/2015 7:37am
ge217 wrote:
No. This is just a spare motor. Last time I did a conversion it didn't go well. Scared to do and ride another one. If I...
Looks like those lower welds had poor weld quality and then took the upper frame tubes with it. That's a damn shame.
ge217
Vero Beach, FL US
11/17/2015 7:46am
Considering you can barely see those welds idk how you would be able to tell that from the pic.. But I can assure you that the weld wasn't poor quality. Do some research, you'll stumble across more of these frame just like this. Cr's as well. Was even told by a very reliably source at kawasaki that the Af 250's they built did the same thing.
Post a reply to: Kx450f Motor Zero hours
