Any idea what’s causing this to the battery?
h20
San Diego , CA US
I have the Aventon Sinch, I just opened it up and noticed battery acid on the prongs.  I have noticed the throttle was cutting out, I figured it was a connection issue.
IMG 6660 0
h20
San Diego , CA US
8/31/2023 8:44pm
IMG 6659 0.jpeg?VersionId=Dkxcr SsZyVb7
Last2Stroke
304th
8/31/2023 9:27pm
Looks like dirt or corrosion, clean both male and female terminals, reconnect and ride!
h20
San Diego , CA US
9/1/2023 11:54pm
Thanks.  This is a foldable bike so the battery stays inside.  I have no idea how it got so dirty so fast.  It wasn’t like this last time I broke it apart.  I’m going to use some electrical cleaner on the prongs, hopefully it fixes it.
Last2Stroke
304th
9/2/2023 1:27am
Use a scouring pad...
image-20230902182436-1
to clean the terminals back to bare metal, then use the contact cleaner.
It looks like the connector isn't sealed, you can apply a thin layer of vasoline around the outside of the terminal...
image-20230902182632-2
to keep moisture, dust and dirt out, just don't get any on the terminals.
h20
San Diego , CA US
9/2/2023 10:42am
Thank you very much!!! Going to do this today after work
9/3/2023 1:10am
If it’s on the positive input, it could be from over charging. Like leaving plugged in to much. If it’s on the negative side, charger is getting week. Also could be a bad connection from it flexing or something.
h20
San Diego , CA US
9/3/2023 11:56pm
I cleaned it today, I’m going to wait until the morning to reconnect the battery.  Hopefully it works!
IMG 6736.jpeg?VersionId=8Q
h20
San Diego , CA US
9/3/2023 11:56pm
IMG 6737.jpeg?VersionId=FLyidNLyRN1cnY5 Qz
h20
San Diego , CA US
9/3/2023 11:57pm
This is what I used
IMG 6738
Last2Stroke
304th
9/4/2023 12:29am
h20 wrote:
This is what I used
This is what I used
IMG 6738
Both will leave residues which are not ideal for electrical connectors, you should use contact cleaner...
image-20230904172459-1
They use Isohexane which evaporates, leaving bare metal contacts.
Vasoline around the terminal should keep moisture out of the contacts and slow oxidation of the terminals, the terminals will be a copper alloy, so their surface will gradually oxidize when exposed to air.
h20
San Diego , CA US
9/4/2023 9:50pm
The fuckers at Home Depot told me that WS 40 was safe for electrical outlets, just be gentle.
they probably had no idea what they were talking about.  The other stuff like degreaser I got to clean the bike.  I didn’t put that in electrical outlet.  I also used the duster air cleaner afterwards so hopefully nothing harmful was left behind.  The connections actually cleaned pretty well.
I went to put the battery back in today and ride and it turns out that dirty connection isn’t the issue!  I am so damn upset.  I used to be able to take apart dirt bikes, now 20 years later I can barely install a brake line.  Stuff frustrates me so dang easily and I get so much conflicting info from YouTube vids.
long story short (thanks for reading so far) my bike turns on and works fine when I hold the battery in place, or LEAN it to the right side.  Any time the bike is level or leans towards the left (kickstand side) it shuts off completely.
I have have someone tell me they think a wire came loose because my bike is foldable, they told me to check the back of the CONTROLLER.  I have only folded it and put it in my car one time and it worked fine for a few rides after, but ever since I folded it something happened.  I have a friend that has the same bike as me but he’s not that knowledgeable, he takes it to the shop, I cannot afford to, but I might have to.
Last2Stroke
304th
9/4/2023 10:44pm
You could ride is a circle, right turns only!
Sounds like a loose or partial connection to the battery, is the battery removable, can you remove it and reinstall it?
early
University Heights, OH US
9/5/2023 5:58am
I wonder if there's a kickstand up switch that's losing contact when you lean it to that side.
h20
San Diego , CA US
9/7/2023 7:44pm
Ok sorry for not reporting back sooner. I got a nasty sickness this week!  One of the worst colds / fevers iver ever had.
but the good news is…  I’ve been able to FIX my problem and the bike rides perfect!
praying it stays working well.  I will explain exactly what I did, what the problem. Was, I will show photos, but basically what it came down to was my bike is foldable and the wires always get pinched and pulled .  I’m have since read a lot of people saying with their foldable e bikes they have connection and controller issues because when they fold the bike the cords stretch inappropriately.  Sucks to read this because I have a car and loved fitting in in my trunk.  I’m really hesitant now .
h20
San Diego , CA US
9/7/2023 7:52pm Edited Date/Time 9/7/2023 7:53pm
 IMG 6823.jpeg?VersionId=f0Lw  ud5p67dETSo I checked the controller for loose cords, everything looked good, so I knew it wasn’t this issue…
IMG 6822 0
IMG 6824
h20
San Diego , CA US
9/7/2023 7:55pm
IMG 6825.jpeg?VersionId=dbuGH
To add to above
h20
San Diego , CA US
9/7/2023 8:02pm Edited Date/Time 9/7/2023 8:11pm
You could ride is a circle, right turns only! Sounds like a loose or partial connection to the battery, is the battery removable, can you remove...
So this is what actually worked!!!
so I removed the BATTERY itself a ton and cleaned it and but I never removed the rack it sits on and has 3 wires under it!
 I saw the slide the battery sits on, it’s only had 3 bolts holding it in.. there are 3 wires that run underneath it.  What I did was reconfigure those wires so the battery would be tight and lean the way I wanted it.  I ended up not being able to attach the battery to the controller because there was a fat cord under the slide , my attempt to raise the battery made the connection uneven.
so I put the rack back in, and I configure the wires basically the same way they were thinking this isn’t going ti fix it.  And waaaalahhhh !  The battery fit in tight and the bike works better than it did before!
these are photos on the slide I’m talking about,
IMG 6827.jpeg?VersionId=Us.CtTO86fh47FR
IMG 6826 0
h20
San Diego , CA US
9/20/2023 5:47pm
Another update.  Almost all these problems come from the foldable feature.  I just snapped another rear brake line.  Damn foldable feature causes so many issues.    I have a small car with it fits in the trunk, but I’m thinking of buying a bike rack on the back of my car.
murriej33
loma Linda, CA US
2/5/2024 11:09am
h20 wrote:
  I have the Aventon Sinch, I just opened it up and noticed battery acid on the prongs.  I have noticed the throttle was cutting out...
IMG 6660 0
We have 4 sinch bikes and 2 have had this problem. When we put foil on the terminal that is black it seems to fix the problem.
Post a reply to: Any idea what’s causing this to the battery?
