Conroe, TX
Rumor has it that in 14', in an effort to fix shifting issues, Suzuki went to a signifigantly stiffer spring on the shift drum follower. (Arm with wheel on it.) What I am looking for as a 16' Suzuki RMZ450 owner with less tham 4 hours on it is for it to stay in 3rd gear when I put it there. Exceed 5k rpm in 2nd and shift to 3rd, and it will stay in 3rd 4 out 6 times. Slips back to nuetral real quick then drops itself back into 2nd. More success if you shift it quickly before gettting to the high revs, but shifting that quick means your not really even fully out of the rut/square edges yet usually. The 2 out of 6 times it doesn't stay in 3rd are the reason the bike I bought for a return to agressive moto is best kept in the woods. Im trying to find a fix for this if anyone is in the know thanks in advance. Weight of bike, no big deal, air fork, well I'll work with it just like the harsh shock. Handles pretty good, but not sinking money into this suspension until I know it will stay in 3rd gear. There is a kit out there with a bearing on the drum follower wheel along with a different spring that is meant to help, but this same kit was meant for the pre-14' Zuks also. Not hearing of anyone who has A- had these problems, and B- gone through the process of resolving them. Anyone in the know?
Plus, I've got the fix for the harsh shock also.
Thanks again and Ill share my results here for others.
The hammerhead +10MM makes the problem go away, or if you have a smaller foot, get a 2007 shifter- its a better shape, you just have to grind a small notch to clear one of the case bolts....i have a new one of these shifters for sale also.
Plus, ive got over sized pegs too
I've got a 2015 RMZ450, put 28 hours on it with the stock shifter and have never had 1 shifting related issue. I've always found it to be super reliable and I have every confidence in shifting before a jump face etc.
Bruce, is that a PC shock piston?
Post a reply to: 14 and newer RMZ450 shifting
