SE
6/19/2022 9:22pm
About to put a new piston in my bike. The bike has 70h on it and the piston 45h.
I am not an engine expert so would like your input.
Does the cylinder look ok or is it worn out?
And what about the valves?
I might bring the top end Down to my local shop so they can take a look at it..
![](https://p.vitalmx.com/photos/forums/2022/06/11/554685/s1200_20220611_184946.jpg)
![](https://p.vitalmx.com/photos/forums/2022/06/11/554684/s1200_20220611_185009.jpg)
![](https://p.vitalmx.com/photos/forums/2022/06/11/554686/s1200_20220611_185025.jpg)
![](https://p.vitalmx.com/photos/forums/2022/06/11/554683/s1200_20220611_185042.jpg)
![](https://p.vitalmx.com/photos/forums/2022/06/11/554682/s1200_20220611_185048.jpg)
![](https://p.vitalmx.com/photos/forums/2022/06/11/554687/s1200_20220611_185102.jpg)
![](https://p.vitalmx.com/photos/forums/2022/06/11/554688/s1200_20220611_185135.jpg)
If it was me, I'd recoat or replace the cylinder and new piston and get the head resurfaced and valve seal checked.
Has any dirt ever got past the filter? What filter oil are you running?
I'd also check the oil pump gears while you're in there and consider replacing with new ones or aluminum aftermarket ones.
I agree, if you have the bike apart, might as well take care of that wear on cylinder and piston.
I bought the bike recently and only done one practice on it. I thought it smooked a little bit more than normal when cold and it also looked like the head gasket didnt seal 100%. It was a little bit oily after riding so thats why I decided to put a new piston in and check the cylinder/valves.
I did send the pics to my local shop mecanic and he said it looked like normal used engine but its Hard to tell from pics he said so I Will bring it to him next week so he can check.
70 hours on the cylinder and its already getting a 3rd piston? What happened to the first one? Why only 25 hours? I know its second owner but still.
My .02, get it replated and matched with an OEM piston. Check valve clearances, if good, leave them alone. Out of spec, shim and check it again in the next 3-5 hours for difference.
I have a 17 350 with 120 hours, valves haven’t been touched still in spec, no rebuilds runs perfect. The 350s just built different lol
Post a reply to: How does my top end look? KTM 350 SXF 2020
