125/150/250/300 KTM/HUS/GG jetting thread
AJ565
San Antonio, TX US
Edited Date/Time 10/11/2023 7:08pm
I get a lot of emails from here and at the track about jetting for the 2 strokes. Thanks to digger for pointing me in the right direction this is the currant specs. I have for everything. Its easier to start a thread With all the jetting in it to keep track of everything. Your jetting might need tweaked based on your temps and elevation, but this is a good start for you.
**Updated 4/19/23**
'17+ 125/150 jetting (‘22 bikes have a known bog, there is no jetting or carb swap combo yet that takes care of that problem. If or when it gets figured out I’ll update)
MJ 510
PJ 32.5
AS 1.75
slide 5.0 from JD Jetting
Needle 42-74 on the 2nd clip (Yamaha 284-14116-H4-00)
Needle jet S4 (KTM part #55431021400)
PV 2.25 turns in from all the way out.
Fuel mix 40:1
(credit to FGR01 for continuing to refine the small bore jetting)
On the '17+ 250's **Updated 10/13/2020**
Pump gas/race gas or straight C12
This is my current jetting. Its more refined all around and crisp down low with better top end over rev.
Main jet 500
Pilot jet 32.5
Slide 5.75 (Kawasaki part#16025-0003)
Needle 43-75 (KTM part #55431134400)
Clip position #2
Air screw 1.5-2.0
Fuel 55:1
OR
Solid jetting if you're someone that doesn't live on top end. Crisp down low out of turns pull.
MJ 490
PJ 32.5
AS 1.5 turns out
Needle jet S4 (KTM part #55431021400) stock is S1
Needle 42-75 on the 2nd clip (Yamaha part #284-14116-H5-00)
Slide 5.5 (Kawasaki part 16025-0002)
PV 1.75 turns in from all the way out
Fuel mix 50:1
300sx jetting
Pilot jet 25 and main jet 460 to start.
5/32” chainsaw file to notch the front of the slide.
A/S 1.5 to start, you’ll need to adjust as needed.
13
Jayklash
8/23/2019 10:11am Edited Date/Time 8/23/2019 10:11am
AJ565 wrote:
I get a lot of emails from here and at the track about jetting for the 2 strokes. Thanks to digger for pointing me in the...
**Updated 4/19/23**
MJ 510
PJ 32.5
AS 1.75
Fuel mix 40:1
Main jet 500
Pilot jet 32.5
Clip position #2
Air screw 1.5-2.0
Fuel 55:1
OR
MJ 490
PJ 32.5
AS 1.5 turns out
Fuel mix 50:1
300sx jetting
Do you have any good jetting specs for the 2018 KTM SX 150 without changing the slide?
AJ565
San Antonio, TX US
8/24/2019 9:32am
Nope, the slide is the key to making the run right. You can modify your own slide with a dermal tool if you don't want to spend the money. The specs. are in a few threads on here about what measurements you need.
AJ565
San Antonio, TX US
8/24/2019 4:31pm
Jayklash wrote:
Will this slide fit? [img]https://p.vitalmx.com/photos/forums/2019/08/24/368207/s1200_Screenshot_20190824_204614_eBay.jpg[/img]
No, that’s a different carb. I’m not sure where to get a 5.0 slide. Maybe digger will see this thread and chime in on where to find one.
opyguy
Boston, MA US
8/24/2019 5:55pm
rocky mountain parts
kx 125 fiche should have the 5.0 slide
jwolfman317
Kechi, KS US
8/24/2019 7:30pm
JD jetting has a 5.0 on their website. The richest kx125 slide was a 5.5 and I felt like it was a little too lean.
garagedog
Tulare, CA US
599th
8/24/2019 7:58pm
Larger the number means there is more air coming through the opening = leaner
jwolfman317
Kechi, KS US
8/24/2019 9:28pm
They offer a 5.5, 5.75, and 6.0 for a kx 125; therefore, the 5.5 is the richest that is offered, yet still too lean for our bike. That is why I went with the 5.0 from JD Jetting.
digger
Upstate, NY US
3931st
8/25/2019 2:48am Edited Date/Time 2/19/2020 6:33am
The best 125/150 jetting setup that I have come up with is:
42-74 needle start out in the #2 clip position https://www.motosport.com/oem-parts/part-number/284-14116-h4-00?mmysour…
S-4 needle jet
#5-slide, it's a must have item. IMO,
#5.5-#6 slides are to lean for the small bore bikes. You can either cut your #4 oem yourself, or you can purchase one from JD jetting.
https://jdjetting.com/product/jdmk02-mikuni-tmx-ktm-husq-carburetor-sli…
Main. 490
32.5--pilot
if you notch the front side of the slide, you will need a 30 pilot
You will also more than likely need a jet block gasket, as the oem ones deform over a very short amount of time.
https://jdjetting.com/product/jdmk05-mikuni-tmx-jet-block-kit/
air screw at 1.5 turns out to begin with.
AJ565
San Antonio, TX US
8/25/2019 3:40pm
Digger, do you have the slide measurements to cut a 4.0 to a 5.0?
jwolfman317
Kechi, KS US
8/25/2019 5:52pm
digger wrote:
The best 125/150 jetting setup that I have come up with is: 42-74 needle start out in the #2 clip position https://www.motosport.com/oem-parts/part-number/284-14116-h4-00?mmysource=yamaha;yz125;2019&partgroup=carburetor S-4 needle jet #5-slide...
S-4 needle jet
Main. 490
32.5--pilot
Thanks for the info, digger. What temp and elevation are these settings good for? Also, what main jet do you recommmend along with these settings?
jpatz319
Statesville, NC US
1138th
8/26/2019 12:45pm
I am running jetting that Aj suggests. The bike runs great but is running way too hot. I bumped the MJ up to a 490. Should I go to a richer slide keep going up in MJ?
AJ565
San Antonio, TX US
8/26/2019 1:28pm
jpatz319 wrote:
I am running jetting that Aj suggests. The bike runs great but is running way too hot. I bumped the MJ up to a 490. Should...
What gas are you running and mixed at what? You can only go up so much with a MJ before it will start to run poor. Unless you're always wide open you may need to drop to a 5.5 slide. My bike also has a 490 in it, but I'm also running u4.4 mixed 44:1.
I have a slide I cut that should be around 5.5 that I can put in my bike and test with and get some solid numbers. It will be a week or so as my suspension is off getting redone.
jpatz319
Statesville, NC US
1138th
8/26/2019 1:44pm
I'm running 50/50 C12 and pump at 60:1. I do ride the bike like a 125 wide open everywhere. I was thinking about running 40:1 and changing the jetting if it is too rich. Do you have the specs for a 5.5? I have my stock slide and can cut to match.
AJ565
San Antonio, TX US
8/26/2019 2:15pm
jpatz319 wrote:
I'm running 50/50 C12 and pump at 60:1. I do ride the bike like a 125 wide open everywhere. I was thinking about running 40:1 and...
I ride mine like a 125 too lol.
40:1 is more oil so it would be leaner fuel mix. I think so, digger posted in another thread 1.5mm deeper and wider on the cut to turn a 4.0 into a 5.5. I have one that I cut that next time I go ride I'll swap into it and see what happens and if I have to change any other jetting. I have a 500 MJ that I need to try also.
Jayklash
8/26/2019 2:16pm
S-4 needle jet
Main. 490
32.5--pilot
So do you only need the jet block gasket if you notch the slide yourself? Also what temp and elevation is this good for? I'm in the uk
digger
Upstate, NY US
3931st
8/26/2019 5:37pm
S-4 needle jet
Main. 490
32.5--pilot
Jayklash wrote:
So do you only need the jet block gasket if you notch the slide yourself? Also what temp and elevation is this good for? I'm in...
Yes, if you cut and notch your oem slide you will only need the jet block gasket kit from JD.
That setup has been used from 60f to 90f with slight air screw adjustments only. Sea level to 2000’
digger
Upstate, NY US
3931st
8/26/2019 5:42pm Edited Date/Time 2/19/2020 5:56am
S-4 needle jet
Main. 490
32.5--pilot
I have them setup with a 490 main. Make sure you use Mikuni brand mains only. The quality of the aftermarket mains above 490 varies wildly. I have seen 520 aftermarket mains that ran leaner than 490’s. Just be advised.
digger
Upstate, NY US
3931st
8/26/2019 5:52pm Edited Date/Time 2/19/2020 6:07am
I dykem blue the back side of the slide where I will be cutting, so that I can see the etched line. I then etch the amount I need to take off around the full arch, 1mm to go from an OEM 4.0 to a 5.0, or 1.5mm to go from 4.0 to a 5.5 etc , into the slide with a caliper. I then grind and blend down to the etched line. I finish(smooth) it up with a sanding drum.
Jayklash
8/26/2019 10:28pm
S-4 needle jet
Main. 490
32.5--pilot
digger wrote:
Yes, if you cut and notch your oem slide you will only need the jet block gasket kit from JD. That setup has been used from...
I am trying to source a 5.0 slide here in the UK but they do not look the same as one pictured on JD jetting site. Is the slide actually for a keihin carb? But fits a mikuni?
digger
Upstate, NY US
3931st
8/27/2019 12:56am Edited Date/Time 8/27/2019 12:59am
The slide pictured on JD's website is the correct slide for a Mikuni TMX-x carb( the slide you need) . A Mikuni TMX-x slide will only work in a Mikuni TMX-x carb. JD's slides will only work in non TPS Mikuni's, which with your KTM, you don't have to worry about.
Jayklash
8/27/2019 3:08am
Ok I am still going to try and sort one in the UK as shipping from the US is about $60 so nearly as much as the slide itself.
Jayklash
8/27/2019 3:21am
digger wrote:
The slide pictured on JD's website is the correct slide for a Mikuni TMX-x carb( the slide you need) . A Mikuni TMX-x slide will only...
Pretty sure I have found one here in the UK here are a couple of pictures can you confirm for me please?
digger
Upstate, NY US
3931st
8/27/2019 3:38am
Jayklash wrote:
Pretty sure I have found one here in the UK here are a couple of pictures can you confirm for me please? [img]https://p.vitalmx.com/photos/forums/2019/08/27/368728/s1200_Screenshot_20190827_111918_eBay.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2019/08/27/368729/s1200_Screenshot_20190827_111849_eBay.jpg[/img]
The slides that are in the pics, are for a Mikuni TMX-x carb, and are what you need. The bottom pic is of an oem #4 slide, exactly like the one you have in your bike now.
Jayklash
8/27/2019 4:03am
digger wrote:
The slides that are in the pics, are for a Mikuni TMX-x carb, and are what you need. The bottom pic is of an oem #4...
Just spoke to the guy again and he said the picture is just for reference he has the same slide in a 5.0
digger
Upstate, NY US
3931st
8/27/2019 4:42am
That’s the one you need.
Jayklash
8/27/2019 5:49am
I am trying to source one direct from mikuni as it is much cheaper. But they said they need the exact dimensions of the slide do you happen to know what they are please?
jpatz319
Statesville, NC US
1138th
8/27/2019 8:15am
AJ565 wrote:
I ride mine like a 125 too lol. 40:1 is more oil so it would be leaner fuel mix. I think so, digger posted in another...
Okay. Do you think you would have to change the needle at all to go along with the slide change?
AJ565
San Antonio, TX US
8/27/2019 8:57am
As in the needle its self or clip position? I doubt either one, but for sure not the needle its self.
digger
Upstate, NY US
3931st
8/27/2019 1:57pm Edited Date/Time 3/11/2020 7:25am
Jayklash wrote:
I am trying to source one direct from mikuni as it is much cheaper. But they said they need the exact dimensions of the slide do...
Why do they need the exact dimension? There are 2 versions of that tmx-x , but the Oem KTM Mikuni is able to use both versions. The Mikuni equipped TMX-x with TPI slides are a slightly different version. They have a semi filled port to allow the tpi to contact the slide, but both are the same dimension wise, with the exception on the filled port.
Post a reply to: 125/150/250/300 KTM/HUS/GG jetting thread
