KTM mods/solutions
Edited Date/Time 2/11/2019 6:30am
I’ve had numerous KTMs now from 2016-19, and was wondering if anyone’s found solutions to few of the problems which occur.
Firstly, is there a rear brake return spring from another manufacture which fits the ktm? Don’t really want to buy a faast one unless I have to because I’m in the UK.
Also, any steering stem nuts with a hole in the centre for vent hose other than WC as my plastic clip comes out whenever the fuel cap is unscrewed.
I currently have a 2019 250sx, so any suggested mods for this too would be great.
Cheers
seth505
SD, CA US
1984th
1/29/2019 7:07am
I run the Faast rear spring and just pull the hose off the plastic plug before you unscrew the fuel cap, I do that every time and have never had my plastic plug come out of the frame on any of my KTMs.
BR8ES
Bennett, CO US
1/29/2019 7:23am
Some have said they used a Honda return spring, I have not however.
1/29/2019 7:32am
Thanks. I’ll give it a go because I have a CR 250 I could take the spring off to try
BR8ES
Bennett, CO US
1/29/2019 7:34am
nice, hope it fits. Looks close from pix anyway.
Luxon MX
San Diego, CA US
312th
1/29/2019 11:33am
I’ve had numerous KTMs now from 2016-19, and was wondering if anyone’s found solutions to few of the problems which occur. Firstly, is there a rear...
Cheers
The Fasst spring works great, but if you can't easily get one then that makes it a moot point. What problem are you having with stock? If it's grabbing your boot and popping out, have you tried flipping it around?
You can buy a full set of our triple clamps if you want a steering stem nut with a hole in it! Laughing Or, just get out the drill and make a hole in the stock nut. There's no problem with doing that, plus it's free.
Lynch
SE
1/29/2019 11:41am
Buy the 2015 or older return spring, problem solved.
1/29/2019 11:45am
Cheers
Luxon MX wrote:
The Fasst spring works great, but if you can't easily get one then that makes it a moot point. What problem are you having with stock...
I keep snapping the stock ones.
I’ll give drilling it out a go, might buy a cheap Chinese one off eBay to try it with first incase I completely ruin it! Whenever I undo the petrol cap, the plastic holder for the vent hose that goes into the frame pops out. Haven’t had trouble before, only on my 19. Must be a dodgy one or something.
Love your 150 build man, can’t wait too see it finished.
1/29/2019 11:46am
Are they any differently to the 16+ springs?
Lynch
SE
1/29/2019 12:31pm
I might have mixed up two parts, if you are talking about the spring on the brake pedal then yes they are shaped differently and won't break if you purchase the older 2015 spring.
BR8ES
Bennett, CO US
1/29/2019 12:43pm
Just matched up the Honda spring, same length, etc.
mx317
TN US
1/29/2019 5:31pm
That is what I had a mechanic for a satellite KTM factory team tell me to use.
BR8ES
Bennett, CO US
1/29/2019 6:19pm
works great, fits perfect and the rubber sleeve is a great addition.
1/29/2019 10:10pm
I would also suggest the older return spring version if you`re facing problems with the current one. Strange but I had three bikes since MY16 and not a single broken spring?!?
The steering stem nut from the actual Freerides have a holoe inside and they should also fit... but as some guys already mentioned drilling for sure is the cheaper version
mx317
TN US
1/31/2019 3:42am
I always slide the rubber hose off the plastic piece that goes into the frame and unscrew the cap. I have never had a problem doing it this way.
ktm-5
Ravenna, MI US
1/31/2019 8:43pm
I would mill the head and tighten up the squish, the quad flow torque wing was the best $100 I spent when we were on 2 strokes
2/7/2019 1:00pm
Looks like it’s not just me that has trouble with springs breaking. I tried to fit the spring off my CR but it’s so worn and stretched it doesn’t fit.
Keefer uses a crf one so I’ll order one soon, and I spotted one on Blake baggetts bike in a video too.
Thanks for the help and advice
BR8ES
Bennett, CO US
2/7/2019 1:08pm
YEP, just get a new one mate. Work like a charm. You can buy me a pint some day.
blaze 57
Inchelium, WA US
2/9/2019 11:18am
Anyone know the # part number or link to get the crf Honda spring? Thanks
2/9/2019 1:24pm
Yes, it’s 46511KZ4J00
Glad you posted this. I have lost so many of these springs of my 2019 ktm 250sxf
2/9/2019 1:50pm
I think a lot of people must have the same issue, poor product. I keep a load spare constantly, but wanted to find a viable solution. Can’t believe red bull ktm use the standard one, unless it’s upgraded in some way? Looks the same though
2/9/2019 1:53pm
Bought a cheap stem nut off eBay, just over £2 on eBay. Drilled it out and finished up pretty good, just hope the nut itself holds up and stays in the stem.
Rickyisms
FL US
2/9/2019 4:45pm
Bought a cheap stem nut off eBay, just over £2 on eBay. Drilled it out and finished up pretty good, just hope the nut itself holds...
I have a couple of these, I'm gonna try this out.
blaze 57
Inchelium, WA US
2/9/2019 7:38pm
Thanks for the #!
2/11/2019 6:29am
Worth doing!
I was looking through some of the pro bike videos in detail and noticed Anderson’s factory 2 stroke used a drilled stem nut too.
Moto520
Schaumburg, IL US
2/11/2019 8:17am
Very cool. Works Connection makes one for $30
mx317
TN US
2/12/2019 7:01am
The drilled nut works well with handlebars with a crossbar. The stock bars or any other handlebar without a crossbar it won't work so well because of the bar pad.
mx317
TN US
2/12/2019 7:08am
You can see on Webb's bike how it covers the steering nut.
Post a reply to: KTM mods/solutions
