PC Works pipes protecting finish
Edited Date/Time 8/18/2018 4:24am
What's the best way to keep a brand new PC Works pipe looking brand new? Some say WD-40, others say high temp clear coat. I don't want to lose the luster.
AJ565
San Antonio, TX US
8/17/2018 11:33am
Scotch brite and gibb's oil. You can use WD-40 as well. It will rust no matter what just from mud when you go ride.
sandman768
Saratoga Springs, NY US
8/17/2018 11:49am
Get the pipe to look like you want it to....sanded, blued welds ect. Then high temp clear coat it...the clear will eventually burn off a rider, but will help with keeping rust away. I also spray them with wd40 after washing, and then put some rubber gloves on & take a rag with motor oil on it & give it a nice wipe down....the raw pipes are great looking but way more work to upkeep...all three of these pipes are high temp clear coated....
H4L
8/17/2018 5:21pm
sandman768 wrote:
Get the pipe to look like you want it to....sanded, blued welds ect. Then high temp clear coat it...the clear will eventually burn off a rider...
+1 on the high temp clearcoat. I sprayed a raw Doma pipe back in 06 & have only done a couple of touch ups from time to time.
Joko
Cromwell, CT US
149th
8/17/2018 7:51pm
Which brand of hi temp paint are you using?
CarlinoJoeVideo
Portland/Los Angeles, CA US
8/17/2018 8:06pm
I hit the pipe with red scotch brite for like 30 seconds every time I was the bike.
I saw on MotoStuff’s Instagram they coated a bills cone pipe with high temp clear ceramic coating. I don’t know anything about it but they posted it the other day.
https://www.instagram.com/p/BmT6W94g3Cl/?utm_source=ig_share_sheet&igsh…
H4L
8/17/2018 9:54pm
I've used the aerosol dupli color brand with good results. The ceramic coating would be a better choice since it's suppose to be chip resistant & more durable.
KDXGarage
AL US
8/18/2018 12:55am
green Scotch Brite and oil of your choice. Don't allow yourself to believe it is clean and does not need a scrub.
Buy some nitrile gloves and have at it after every wash. It will take less time after some practice.
HenryA
Stockholm SE
8/18/2018 4:24am
Like mentioned above, high temp clear coat is what you need.
Pirate421
MA US
8/18/2018 2:03pm
I had a raw pipe on my last Ktm for 4 years after every wash I hit it with wd40 and a green scotch Brite and then wiped with a rag. It took less than 3 minutes every time and looked great all 4 years never any rust
Post a reply to: PC Works pipes protecting finish
