Knoxville, TN
1314th
11/4/2018 9:09pm
Bought this 2003 in June and my little girl wasnt too excited about it so it's not been ridden much. Got it out then other day and it wouldn't start. When I kick with choke on it will occasionally run for about 5 seconds and then die out. I will need to fix the kickstarter as the kick starter spring is broken as well. When I check plug it's getting plenty of gas, even swapped plugs. So far I have cleaned the carb, new spark plug, new spark plug cap, fresh gas, and added seafoam in tank( drained carb and pushed some into carb from tank. Dam thing still wont stay running. The last time she rode it the throttle stuck and it scared her pretty good, so when it got put up it was running...
Is the petcock flowing, vent lines not pinched / clogged? Tank venting ?
Post a reply to: PW50.... another wont start
