10/23/2022 10:13am
Hey guys, I found a beat up 2006 450 smr that I’m fairly sure is an ex Australian supermoto race team bike. Cosmetically it’s toast. But the bones are all still in pretty good condition with the exception of a few things. And I picked it up really cheap.
The plan is to strip it to a bare frame and rebuild it as either 2005 Ben Townley 450sxs or a 2003 Joel Smets 450 replica. Either way it’s a good base to start from. Apologies for not getting good photos before stripping it down
SXS Closed cartridge forks
SXS Shock
SXS 2 piece clutch cover
SXS/Powerparts slipper clutch
6 speed gearbox
Flowed cylinder head
Split stream carb intake and Ikat spark enhancer 😂
Complete Akrapovic system
SXS fuel cap
SXS front disc
https://aomc.mx/SXS03540550.html
I did some digging and I think they did 2 different versions of the 540sxs kit depending on the age. I think they did a 97mm piston 72mm stroke version, and a 100mm piston with maybe 68mm stroke? I know the 100mm cylinder is much different looking, the water jacket is huge
I’ve got an 06 RFS, mine is a 450xc, that’s a short stroke 6 speed with e-start. I did a 99mm big bore for a 490, it’s a sweet combo.
Look around, there might be e-start kits still available. Take care of your cam and countershaft, availability is getting tough for them, although there is aftermarket countershafts out.
Great bike!
That’s a really cool bike with some super trick parts! Excited to follow this one.
Checked the KTM Spareparts Finder there was no 525 SXS made just a 450 SXS from 2003-2006 so you found a very Special bike
I follow your build that Era was one of the best looking KTM‘s ever for me
I think it’s an ex Aussie race team bike as why it has so much cool stuff, I just assumed they would have used the a 525/560 as a base for the open class so I didn’t think any more of it.
It’s been a little while since I’ve done an update. This is the exact bike I’ll be building a replica of. I’ve been collecting parts in the mean time and found some really cool stuff. I managed to score a 2003 factory Smets seat, a 2002 works WP Shock and even the correct factory cable clutch assembly that Joel used to run
Post a reply to: 2003 KTM 550 SXS Smets replica
